marklmd Posted October 31, 2018 Share Posted October 31, 2018 Hello I looked at F1 and still could not figure out how to make this connection between objects. RBD Material Fracture has its own constraint system and in this way is not done, but to connect different fractures, such as the image example, you need to use Connect Adjacent Pieces, but I could not get Constraint Network to identify this constraint between the objects. I used the old method to paste as pieces and can not make the two examples dialog Quote Link to comment Share on other sites More sharing options...
DonRomano Posted October 31, 2018 Share Posted October 31, 2018 If you can add the file I may help Quote Link to comment Share on other sites More sharing options...
marklmd Posted October 31, 2018 Author Share Posted October 31, 2018 (edited) On 10/31/2018 at 10:57 AM, DonRomano said: If you can add the file I may help Expand https://www.dropbox.com/sh/u8r368ricyv7bu4/AADrLP3RKshzjBIAu-bMTwjMa?dl=0 In this project I try to stick to parts of a wall using the RBD Material Fracture SOP Edited November 1, 2018 by marklmd Quote Link to comment Share on other sites More sharing options...
