kubabuk Posted May 10, 2006 Share Posted May 10, 2006 Hi, Is it possible to delete one of group from groupSOP? Quote Link to comment Share on other sites More sharing options...
thekenny Posted May 10, 2006 Share Posted May 10, 2006 If you want to remove a group (point or primitive) for your geometry you can do so via the groupSOP --> last tab (Edit) at the bottom (Delete:Group). Just be careful that the default for the groupSOP has the enable toggle ON for the Number grouping method... this will make a new group of everything in your geometry.. so turn it off if you don't want to add a new group and want to just delete one. You can combine/subtract/difference groups under the Combine tab of the SOP as well is this what you wanted? -k Quote Link to comment Share on other sites More sharing options...
kubabuk Posted May 10, 2006 Author Share Posted May 10, 2006 Exactly, you helped me a lot, thanks thekenny Quote Link to comment Share on other sites More sharing options...
