intersect() inside material builder
nuki
Inside a material builder I would like to use the intersect() function. As I couldnt get it to work with the op:/obj/path_to_mesh syntax or any other way I was wondering if using intersect() is even possible in mat context? Also, is there a simple way to return the scene path to the geo the current sample belongs to?
23 hours ago, 3dome said:
I'm not sure if that is always true.. have a look at this very simple example
dm_IntersectInSHOPs.hip
pretty interesting, was it always like this? i was doing some stuff with point clouds in shader and never could make this work in earlier versions. anyways i'm glad it works now :)
Edited by davpe
