Random Scale of Spheres
ChazS
I'm trying to randomize the uniform scale of some spheres which are being copied to points. However, nothing I've tried is working. The best result is using a transform node, but all the spheres merely scale to the first parameter and ignore any type of randomization. The attached file currently has an app wrangle using some vex to randomize pscale that was defined in an att created node, but it's throwing errors I don't understand how to fix.
Thanks in advance...
wk5_terrain-02.hipnc
