How to selects a point ID using VEX?
Zetha
Thanks,
I have been able to do with the SOP nodes, but I am not able when I try using only VEX.
When I type:
if (@ptnum = 56) {
    v@P.y = v@P.y + 2;
It moves the whole grid of points. How can I move only the point 56?
I cant figure how to select a single point of a grid with the code
The most obvious problem here is that you're using = instead of == in your conditional statement.
That said, because point wrangles are always running in parallel (all points are processed "simultaneously"), isolating a single point like this is bad form. You should consider using "56" as the group mask for the wrangle instead, or create a point group upstream if you need more points than that.
