Creating some different copies of digital asset with different values from a table
Christoph_H
whats the best way?
I have a digital asset with 4 parameters. I want to create some copies of this based of different parameter values from a table file.
It would be cool to read and create automatically geos. My python skills are very very rough.
I don't know how to begin.
Can you help me?
thanks.
import csv
file = hou.ui.readInput('Enter the full path of the csv file', buttons=('OK', 'Cancel'))
if(file[0]==0):
    with open(file[1], 'rb') as f:
        doc = csv.reader(f)
        for row in doc:
            node = hou.node('/obj').createNode('geo') #create instances of your HDA here instead
            node.parm('px').set(row[0]) #set the correct parameter of your HDA
            node.parm('py').set(row[1])
            node.parm('pz').set(row[2])
            node.parm('prx').set(row[3])
            node.moveToGoodPosition()
edit: attached sample CSV to go along with code
testtable.csv
Edited by 3dome
attached sample csv
Thank you. It's really helpfull.
But I have two questions:
How exactly do I set the HDA? I could not use the asset name in my scene. Or do I have to specify the directory path of the hda?
How do I define the selection of certain vertical columns in combination with horizontal rows?
thank you.
Edited by Christoph_H
5 hours ago, Christoph_H said:
Sorry. My mistake. it works.
But the other question would still remain. How can I additionally work with the vertical columns?
I don't think you can directly read columns with the python csv module. You gotta do some search in the documentation or on stackexchange, etc
You mean something like directly accessing a cell like B3? https://stackoverflow.com/questions/5757743/how-can-i-get-a-specific-field-of-a-csv-file
See first answer, Update 2
Edited by 3dome
thank you so far.
hopefully the last question: :)
I want add setName to my created nodes, but it doesn't work.
import csv
with open('path', 'rb') as f:
        doc = csv.reader(f)
        for row in doc:
            node = hou.node('/obj').createNode('hda')
            node.parm('w').set(row[0])
            node.parm('t').set(row[1])
            node.parm('angle').set(row[2])
            node.setName("test_")
it doens't work because if you look in the very helpful Houdini python documentation you see that the argument unique_name defaults to False.
So the script tries to create a node with a name that already exists (created in the first iteration of the loop).
2 ways to fix that:
1)
import csv
file = hou.ui.readInput('Enter the full path of the csv file.', buttons=('OK', 'Cancel'))
if(file[0]==0):
        doc = csv.reader(f)
        for idx,row in enumerate(doc): #using enumerate to get the iteration
            node.setName('test_' + str(idx)) #adding the iteration number to the string to create unique names
2) node.setName('test_', True)
