Lens Shader lighting change
I'm trying to get into writing lens shaders. For some reason, when I apply the lens shader, the lighting changes as well. As you can see in the images this is more than just a gamma issue. Maybe I need to export some special variables for the shaders used in the pighead, or its another case of the '/shop to /mat context' transition not being fully complete?
Lens_Shaders_v001.hiplc
Edited by nuki
If somebody could give me a hint which kind of Operator Type I should choose for a lens shader asset in h17.0.352 I would apprecialte that. I assume VEX / CEX Vop would be correct, but maybe its not ¯\_(ツ)_/¯ .
