Ipr In Apprentice
hi
i can not use the ipr render tool, cause of a no licence warning. so just a quick question is it deactivated in apprentice?
martin
27791[/snapback]
I don't think it's deactiveted... are you able to launch regular Mantra renderer? When you get your NC license, did you make sure to tell the Lic. Admin. to retrieve the Render token?
Take care,
Alex
It work's now. I installed the brandnew release and everything is fine.
Thanks
martin
Take care,
Alex
27792[/snapback]
it's back, arghh
this is the message now:
17:54:41 mantra1 frame 32
UT_NetPacket::write: No such file or directory
License Error: incorrect version of hserver detected
No licenses could be found to run this application.
Please check for a valid license server host
I'm not sure why this happens sometimes, can somebody explain me what this means.
when I want to use both of my cpus, I get this:
mantra: Network Error[localhost] Unable to communicate with remote hserver
Deep resolvers are not currently supported for network rendering
Cannot render ipr
mantra: Network Error[localhost] Unable to write data
mhhh??
martin
