voroinoi fracture points
potato
[SOLVED]
Hello everyone, I have a question concerning voronoi fracture points.
I want to fracture a wall using voronoi fracture points (i must use this), so i load in the wall scatter some points put in in the nodes and it shows the meta balls in the fracture points node (screen2), but the problem is when i want to view the voronoi fracture it shows nothing (screen3).
I have used this technique before (screen1) and it worked just fine, but with this wall i can't seem to find the problem.
Any help would be very apreciated :)
Edited by potato
Thanks a lot for your advice I really appreciate the help! :D
I tried the iso offset but that didn't work, but I replaced the first input from the voronoi fracture points with a box that had kind of the same dimensions as my wall and it worked!
Have a great day!
