potato Posted December 28, 2018 Share Posted December 28, 2018 (edited) [SOLVED] Hello everyone, I have a question concerning voronoi fracture points. I want to fracture a wall using voronoi fracture points (i must use this), so i load in the wall scatter some points put in in the nodes and it shows the meta balls in the fracture points node (screen2), but the problem is when i want to view the voronoi fracture it shows nothing (screen3). I have used this technique before (screen1) and it worked just fine, but with this wall i can't seem to find the problem. Any help would be very apreciated Edited January 4, 2019 by potato Quote Link to comment Share on other sites More sharing options...
Mark01 Posted January 2, 2019 Share Posted January 2, 2019 It could be because the box isn't a volume. Try putting an isoffset before the scatter Let me know how you get on 1 Quote Link to comment Share on other sites More sharing options...
potato Posted January 4, 2019 Author Share Posted January 4, 2019 Thanks a lot for your advice I really appreciate the help! I tried the iso offset but that didn't work, but I replaced the first input from the voronoi fracture points with a box that had kind of the same dimensions as my wall and it worked! Have a great day! Quote Link to comment Share on other sites More sharing options...
