juicysoup Posted January 1, 2019 Share Posted January 1, 2019 (edited) Hey, I've been trying to figure out how to control a fracture of copied packed objects but I feel very stuck. Each object should have their own inital frame to start fracturing on and they should be able to overlap for example A from F1-30, B from F10-40. The fracture should also be from top to bottom. Would love so much if anyone could help me in the right direction! Thanks! fractureMultiple_controlled.hiplc Edited January 1, 2019 by juicysoup Quote Link to comment Share on other sites More sharing options...
anim Posted January 1, 2019 Share Posted January 1, 2019 one of the possible ways fractureMultiple_controlled_mod.hiplc 1 Quote Link to comment Share on other sites More sharing options...
juicysoup Posted January 2, 2019 Author Share Posted January 2, 2019 2 hours ago, anim said: one of the possible ways fractureMultiple_controlled_mod.hiplc Thank you very much this is great help!! Quote Link to comment Share on other sites More sharing options...
juicysoup Posted January 3, 2019 Author Share Posted January 3, 2019 (edited) When I swapped out the geo with my higher res model my computer couldnt really handle it so I prefractured it and then ran the simulation. After two hours I found out two pieces were bugged and floating but the rest of the simulation worked. With other models it works fine...just the one I need to use has two floating pieces after the simulation. Is this a problem with my model? Edited January 3, 2019 by juicysoup Quote Link to comment Share on other sites More sharing options...
