VasAnt Posted January 12, 2019 Share Posted January 12, 2019 (edited) Hi, I was wondering which is the best method to delete the RBD active geo based on a certain Y position value. Thanks! Vas Edited January 12, 2019 by VasAnt Quote Link to comment Share on other sites More sharing options...
anim Posted January 12, 2019 Share Posted January 12, 2019 (edited) plug POP Kill DOP into Post-Solve of Rigid Body Solver DOP and use rule like: dead = @P.y < 0; EDIT: if you really want this to work only on active RBDs as you mentioned, you can specify that in the Group parameter of the POP Kill DOP: @active=1 this will be necessary only if you have some inactive RBDs under that Y threshold that you want to keep there, otherwise you don't have to specify the group Edited January 12, 2019 by anim Quote Link to comment Share on other sites More sharing options...
VasAnt Posted January 13, 2019 Author Share Posted January 13, 2019 Thats working great, thank you Tomas! Quote Link to comment Share on other sites More sharing options...
