Rotate Wheel
I'm trying to build an animation where a wheel rotates based on the path of the axis, axis in this case being a simple primitive although, I don't know how to get the wheel to follow the axis and rotate based on the velocity of the axis (cube) ?
I have the path for the cube but stumped on getting the wheel to follow the cube and to rotate.
For the rotations you take (PI * radius)**2  and add that to the translation. You'll probably want to convert from radians to degrees. So for a circle translating in X and rotating in Z you could put something like this in the Z rot parameter...
-deg(pow($PI * (bbox(opinputpath(".", 0), D_XSIZE)/2), 2) + ch("tx"))
  • Thanks 2
