make chop not cook all the time all the time range!!!!
pelos
I am working grooming some curves/hairs   and all the way below the chain is a chop node with noise inside a subnet,  even do I bypass the subnet, every time I change something takes forever since the chops cook even do that I think they are off/bypass, all the frames =(     is there a way to really by pass chops  or just let them cook by frame so the scene??? is kinda annoying =(
on your generator CHOPs you can set Channel Range to be Use Current Frame
Some CHOPs have also the Time Slice checkbox
but it ultimately depends on your CHOP net and what's happening in there, if you are grabbing Geometry, channels, how you are exporting it back to your scene, etc.
