AntoineSfx Posted January 26, 2019 Share Posted January 26, 2019 I have several features of an animation tracked in Davinci Resolve. In Resolve (Fusion really) I can export it to a text file, the format is: DFMO 0.750000 0.140625 0.000000 0.750073 0.140554 0.500000 0.750146 0.140483 1.000000 0.750179 0.140426 1.500000 0.750212 0.140369 2.000000 i.e ( Column0 space clumn1 space column2 ) relative_X relative_Y time What is a path to an animated null ? Quote Link to comment Share on other sites More sharing options...
Spike Posted January 28, 2019 Share Posted January 28, 2019 (edited) On 26/01/2019 at 3:17 PM, AntoineSfx said: I have several features of an animation tracked in Davinci Resolve. In Resolve (Fusion really) I can export it to a text file, the format is: DFMO 0.750000 0.140625 0.000000 0.750073 0.140554 0.500000 0.750146 0.140483 1.000000 0.750179 0.140426 1.500000 0.750212 0.140369 2.000000 i.e ( Column0 space clumn1 space column2 ) relative_X relative_Y time What is a path to an animated null ? if the format is like this save the file as csv - and import it with the table import sop -> now you got these points as attributes, then i would check out this page http://wordpress.discretization.de/houdini/home/intermidiate/animation2/ + and merge the object with the keyframes with the object to animate Edited January 28, 2019 by Spike Quote Link to comment Share on other sites More sharing options...
