clintond Posted February 5, 2019 Share Posted February 5, 2019 Hi. I'm struggling to solve what should perhaps be an easy problem; - Release a fixed number of points with an animated point attribute, using POP's. Here's what I'm trying to do; - Take a packed object of fractured pieces. - Pass it to POP's. - Treat all objects as static as first. - Then release each object using POP's, using an animated point attribute. - Use transformpieces to animate the packed object. I'm able to do this with the RBD solver, but it takes an incredibly long time. I don't need the accurate collisions of RBD, but really need the speed of doing this with POP's. Below is a side-by-side scene showing the setup working if I animate the particles using @P, versus my setup that doesn't work because it relies on an animated attribute that doesn't get passed through to the points (because they are born on frame 1 and have fixed attributes). Help really appreciated! clinton release_particles_from_animated_value.hipnc Quote Link to comment Share on other sites More sharing options...
