POP Curve Force, @oncurve - how to?
HM_2020
I am killing particles based on their @oncurve value, everything works.
Once I add another curve to the equation, in geometry spreadsheet, every particles @oncurve is instantly 0.
To be clear, I am making separate new POP Curve nodes for each curve, not throwing several curves into one node.
How do I differentiate from different @oncurves from each curve?
Cheers!
Edited by HowardM
  • 2 weeks later...
Hello howard,
You can create differents oncurve attribut per pop curves.
allow editing contents on popcurve node and in the geometry vop, there is a bind export node set on "oncurve", make it "oncurve1" for example
and for the other popcurves do the same "oncurve2..etc
you wil have separate attribut per popcurve.
