jyh126 Posted February 18, 2019 Share Posted February 18, 2019 Hi guys, I need some your help. I'm making torch effect but there is some problem. My fuel doesn't follow emitter and remain in place during few frames. So flames don't be connected, as you can see at my attach files. How can I fix it? I adjust substeps value but it doesn't work. I would appreciate some help. Thanks!! Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted February 18, 2019 Share Posted February 18, 2019 Did you add a trail sop before sourcing to compute your velocity? Also turning on advect fuel would help. 1 Quote Link to comment Share on other sites More sharing options...
Midasssilver Posted February 18, 2019 Share Posted February 18, 2019 I'd post a hip if I were you, but the first thing I can suggest just from your pics is to change the burning rate to .999 or 1. If you have a value less than that, the fuel will remain in space, and give you a trail you may not like. 1 Quote Link to comment Share on other sites More sharing options...
jyh126 Posted February 19, 2019 Author Share Posted February 19, 2019 Thanks soooooo much guys!! Your tips make work normally! Quote Link to comment Share on other sites More sharing options...
