Limit dynamic fracturing of packed primitives?
etudenc
Hey, I'm doing a "simple" simulation of a ball hitting a brick wall using packed primitives. I'd like for the bricks that get impacted to fracture again and so added a Voronoi Fracture Configure Object.
Everything works fine, except all the bricks fracture, not just the ones impacted.
I know I can increase the Min/Max Impact amounts and adjust the Impact Radius to limit what gets fractured, but I'm hoping there's a way I can manually limit the effect to a region of bricks. I've tried making a dynamics group but no good.  Is there an attribute I can set at the SOP level, maybe in a point wrangle (like i@active=0 to set active), that would disable the fracturing of specific bricks?
I've had success doing this with RBD objects but can't get it to work with packed prims and, given that it's Houdini, I feel sure it can be done!  Any help/suggestions would be greatly appreciated!
Hoping someone might have suggestions?
