Add all of a node’s parameters to a take?
  • 1 year later...
  • 1 year later...
1. first make sure you under auto take mode.
2. You can use python code to run through all the parms( parameters = node('YourNode').parms())
and then, use a for loop to store the value, set the parm to anything, then set the value back to the stored version.
3. because there's value change in parm, therefore the parms that processed will be added to the current takelist.
