Align normal by upwards edge
Hi.
I was wondering if there is a way to align the normals by the edge direction?
In the picture below I have the normals aligned almost as I want them. The problem is that the normals are calculated from the edge before and not the actual edge. In my mind I want the normals to be perfectly aligned with the edge flow.
Edited by hampuseh
Depends on the input mesh I guess, but I've attached a sample scene that might give you an idea on how to tackle this problem.
A wrangle SOP which loops through points neighbours and stores the direction to the one thats most "up" as defined by an up vector. Plus one way to handle the corner case of  points with no neighbours above. I've used something very similar to this in an effect in the past.
find_upwards_neighbour.hiplc
find_upwards_neighbour.hiplcFetching info...
Expand
I will try your approach as soon as I can. Looks very promising since the detail of my trunk is also from a mountain-sop. I do wonder if connected pieces to the trunk will follow the same logic. But I will check back here once I've tested it out :)
Much appreciated!
