Houdini Fracture into 3dsMax
We export 3dsMax-geometry (asigned sub-material) as Alembic with ogawa option.
In Houdini, We import it through Alembic(SOP), The Primitives are recognized by gruop "Max_Material_ID_*", but number is -1 compared 3dsmax-Submaterial-ID.
using Voronoi fratcure, it's create nrew group "inside" into breaked new surface.
DOP using this, no problem.
SOP import DOP result, unpack after DOP-import and change Cd with Color-SOP, Primitives keep their group.
Export ROP-Alembic with ogawa option.
3dsMax, import Alembic, the material asign is incorrect.Out-surface is 1, Break-inner is 2, missing surface asign.
Show vertex color, ther are correct, same as houdini.
from this result, we can re-asign muslsub-ID with max-script using vertex color value,
but is's not comfortable.
Is there a better way?
thanks
Destructure_Max2019_v006.hip
Edited by saca
  • 2 weeks later...
