lozruh Posted March 15, 2019 Share Posted March 15, 2019 Hi There, I am bending a strip I have been working on into a circle. I know the two ends will kiss each other perfectly as I had initially modeled this strip as a ring and unfolded in rhino. So now I wanna do the reverse process in houdini. I have tried to use the bend node but did not quite work. I have also attached the file and the reference geometry: https://we.tl/t-TO941ao6mh Thanks! Quote Link to comment Share on other sites More sharing options...
bonsak Posted March 15, 2019 Share Posted March 15, 2019 Increase the Capture length to ca 5.13 and set Bend to 180. Then duplicate the Bend SOP and set its Capture direction to 0,0,-1 -b Quote Link to comment Share on other sites More sharing options...
lozruh Posted March 16, 2019 Author Share Posted March 16, 2019 Thanks a lot this is very helpful! Best, Levent Quote Link to comment Share on other sites More sharing options...
