Sign in to follow this
juicysoup
Particle substep without affecting source?
Hello, I have a popnet with that emits one particle every 10 frames and I need to increase substeps to get more accurate result...however when I increase substeps it affects pop source and emits more particles. For example if I have 3 substeps, it will emit 3 particles instead of one. I've tried using gasintermittentsolve but when using that it just won't emit anything at all unless frames between solves is set to 1. Is there any other workaround for this?
Thanks
Share this post
Link to post
Figured, I could just simulate at higher substeps and then delete the points that I don't need but I guess this isn't an ideal solution
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
