DEBRIS AND POPNET
Hi, I'm Kind of new into this Houdini world and is not an easy world, but I like it, I got this problem:
I want to make a fracture with debris, but I want that my debris wit its own geometry, So I searched, and what I understood was this:
In the picture the null(out_dust) is the geometry that I want for my debris, and blast 3 is just the popnet but without a floor , when i watch the copy node is working but not correctly, the debris have the geometry that i want but the simulation is wrong, I made an example using poplocation and it works just fine, I don't know if the problem here is beacuse im working with a popsource, any kind of help will be really appreciated.
ps: sorry for my english.
Yes, of course the fbx wont work, and neither the cache but if you watch the workflow you can probably help me,
thanks,
Is a non commercial houdini 16.5
practica_fracturas.hipncFetching info...
i found the solution just by adding a point wrangle at the end of blast 3 adjusting the pscale, this would also work with a pop wrangle inside the popnet :)
Edited by cristian_tac
Solved
