omegauser9 Posted March 19, 2019 Share Posted March 19, 2019 I had to re-install houdini after a computer failure and afterward, I went through re-installing my plugins. after I'd install one of them, I'd save it as a 'permanent default' and it would be put into $home="Documents/houdini" and when I open it in that same project, it works fine, but if I open another project, the assets don't load. I'm wondering if maybe I can/ need to change where digital assets save to? I've re-installed several times and nothing's working. I'm not quite sure what i'm doing wrong Quote Link to comment Share on other sites More sharing options...
Andrea Posted March 19, 2019 Share Posted March 19, 2019 In the Houdini enviroment file placed in documents/houdini17.0 you can add the path of your digital assets. You just need to add a line to tell Houdini where to look for them. For example: HOUDINI_OTLSCAN_PATH="C:/here_your_path for_hda; @/otls" I usually place them all together in one folder so is easy to find/replace/remove them if needed. You need to keep the end part with @otls Quote Link to comment Share on other sites More sharing options...
omegauser9 Posted March 20, 2019 Author Share Posted March 20, 2019 (edited) It worked, thank you very much! Edited March 20, 2019 by omegauser9 Original post was question Quote Link to comment Share on other sites More sharing options...
