For loop expression
philpappas
Hit the Create Meta Import Node on the Block Begin node and plug that in to the 2nd input of an Attribute Wrangle.
Then loop over the geo inside the forloop according to the number of the iteration.
for(int i = 0; i < detail(1, "iteration", 0)+1; i++)
        f@myAtt /= 2;
If you are inside the loop and accessing an attribute which is outside the loop, it won't be updated with the results of the processes inside the loop.
Doing it inside an attribute vop like that is a lot more fiddly. I would just run that vex code above, to get your attribute values and then feed that in to the vop to do your various noise calculations.
Sorry, but I can't upload any files at the moment. I'll try to put something together this evening.
just create 'null' object inside the loop (just after 'repeat_begin1') and reference it instead of referencing 'attribcreate1'.
you 'attribcreate1' has same value on each iteration because it is not within a loop.
Edited by tmdag
thanks that fixed it!
