awesomedata Posted March 26, 2019 Share Posted March 26, 2019 (edited) Is there a method that lets me select (and group) all (_only_) the particular corners of a rectangular shape, and then tag them as NW, NE, SW, SE? For example, I want to select and group _this_ SW corner angle on _all_ rectangles in the geometry: Edited March 26, 2019 by awesomedata Quote Link to comment Share on other sites More sharing options...
awesomedata Posted April 17, 2019 Author Share Posted April 17, 2019 :'( Edge selection... Quote Link to comment Share on other sites More sharing options...
anim Posted April 17, 2019 Share Posted April 17, 2019 Group SOP (type Edges) - uncheck Base Group/Enable - check Keep By Normals - set Spread angle to something small, like 5 - set direction to: NE: {-1, 0, 1} NW: {1, 0, 1} SE: {-1, 0, -1} SW: {1, 0, -1} considering based on your screenshot that Z is N and X is W Quote Link to comment Share on other sites More sharing options...
awesomedata Posted April 17, 2019 Author Share Posted April 17, 2019 Nice! -- Thanks! To reward your awesome generosity -- I have two more questions: First, what does the 1/-1 mean in that context? -- I would assume it would be 45 or so (as in degrees), but this doesn't seem to matter. Second, what would I do if I wanted to get the center point of each edge segment in a group? Seriously though -- I do appreciate your help, @anim. I've been wracking my brain when working with edges for quite a while now. I guess I don't quite understand what's going on quite yet. Quote Link to comment Share on other sites More sharing options...
anim Posted April 18, 2019 Share Posted April 18, 2019 1. it's a direction vector the normals are compared to 2. Detail Wrangle with your geo in the second input (assuming your edge group is called "edge_group") int pts[] = expandedgegroup(1, "edge_group"); for (int i=0; i<len(pts); i+=2){ vector P0 = point(1, "P", pts[i]); vector P1 = point(1, "P", pts[i+1]); vector P = avg(P0, P1); addpoint(0, P); } ts_point_per_edge_in_edge_group.hip Quote Link to comment Share on other sites More sharing options...
