zoki Posted June 11, 2006 Share Posted June 11, 2006 Hi can someone help me how to fix collision tolerance on this because metaballs are protruding through glass mesh? thanks z popsCollision.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Val Posted June 12, 2006 Share Posted June 12, 2006 zoki said: Hican someone help me how to fix collision tolerance on this because metaballs are protruding through glass mesh? thanks z 28492[/snapback] use metaballs size for particle size, then metaballs do not cross collision-mesh --- Val Quote Link to comment Share on other sites More sharing options...
zoki Posted June 12, 2006 Author Share Posted June 12, 2006 yes i tried that but it dint work well i will try again and let you know thanks z Quote Link to comment Share on other sites More sharing options...
Val Posted June 13, 2006 Share Posted June 13, 2006 zoki said: yes i tried that but it dint work welli will try again and let you know thanks z 28514[/snapback] hey just did litle test and works .. --- Val Quote Link to comment Share on other sites More sharing options...
aracid Posted June 13, 2006 Share Posted June 13, 2006 Val said: hey just did litle test and works .. Val 28555[/snapback] hey there val what variable are u setting in pops that allows u to offset the collisions like that ? Quote Link to comment Share on other sites More sharing options...
Jason Posted June 13, 2006 Share Posted June 13, 2006 Val said: hey just did litle test and works .. --- Val 28555[/snapback] Hey, those a nice little screen capture:) How do you do that? Quote Link to comment Share on other sites More sharing options...
zoki Posted June 13, 2006 Author Share Posted June 13, 2006 yes very nice! i setup interact particle size to be the same as metaballs radius and it is still getting through can you post your hip? thanks z Quote Link to comment Share on other sites More sharing options...
MIguel P Posted June 13, 2006 Share Posted June 13, 2006 zoki said: yes very nice!i setup interact particle size to be the same as metaballs radius and it is still getting through can you post your hip? thanks z 28559[/snapback] Yes please, post your hip Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted June 13, 2006 Share Posted June 13, 2006 [quote name='MIguel P plim_collideShift_v01.hip.gzFetching info... Quote Link to comment Share on other sites More sharing options...
Val Posted June 13, 2006 Share Posted June 13, 2006 hiya. for screen capture I use http://www.hyperionics.com/hc/ and then I render animated-GIF. === Yes, exactly like the Usual Alex posted! He must have ESP. hehheheheh (The only difference is that for particles emmiter I used a grid ) --- Val Quote Link to comment Share on other sites More sharing options...
zoki Posted June 14, 2006 Author Share Posted June 14, 2006 ok thanks alot I will check it currently i am fixing flying arrows tutorial from book and guess what they fly! now I am adding swing in tail.... z Quote Link to comment Share on other sites More sharing options...
