how to import point (attribute VOP)
- you can use foreach loop to accumulate the falloff value
- also if will help to have f@pscale attribute on your points or spheres to be able to have varying radii
- and instead of looping through all of them you can loop just through points that would influence the point using pcfind_radius()
f@falloff = 1;
int pts[] = pcfind_radius(1, "P", "pscale", 1.0, @P, 0.0, 1e9);
foreach(int pt; pts){
    float r = point(1, "pscale", pt);
    vector P = point(1, "P", pt);
    float dist = distance(P, v@P);
    f@falloff = min(f@falloff, fit(dist, 0, r, 0, 1));
how_to_import_all_points_fix.hip
  • Thanks 1
Sorry, I don't really understand what you are trying to do. An attribute vop does run on all points that are plugged into the attribute vop. Anything done inside the attribute vop will run on all the points. Then you said you want the same gradient on all the points. That part really doesnt make sense. It looks like you have a color gradient on your grid, but the only reason you are seeing that is because it is a collection of points. Each point only has 1 color, so it's impossible to have a gradient of color on any one point. Maybe ask your same question differently and it will make more sense.
f@falloff = 1;
I have no idea how you gauged that that was what he was trying to do lol
