imoh3n Posted April 10, 2019 Share Posted April 10, 2019 Hi all I have a dop network with two packet object (ground and balls). I add a sop solver to emit some spheres in each frame. The problem is in each frame new spheres added to ground and balls dop object either. How can I force sop solver to add spheres to ball dop object only. I hope my question was clear. Thanks. Quote Link to comment Share on other sites More sharing options...
imoh3n Posted April 10, 2019 Author Share Posted April 10, 2019 Actually I know if I separate rigid solver, the problem solved but I wondering is there any trick to make this by one solver. Quote Link to comment Share on other sites More sharing options...
Ryan Posted May 5, 2019 Share Posted May 5, 2019 Here are 3 ways to emit packed prims. Hope this helps. emitting_packedprims.hip 1 Quote Link to comment Share on other sites More sharing options...
rayman Posted May 8, 2019 Share Posted May 8, 2019 You can add empty data to the object you want to emit in, name that data , then add enable solver after the sop solver and type the same name to the Enable Data parameter. 1 1 Quote Link to comment Share on other sites More sharing options...
