Justin K Posted April 11, 2019 Share Posted April 11, 2019 Hey! Can anyone explain the difference between these two approaches when applying velocity fields to a pyro sim? Example 1: sop vector field piped into a field force after the pyro solver itself Example 2: Same sop vector field imported into dops using a source volume dop. Volume is called force. This volume is called in a gas advect dop --piped into the advect input of the pyro solver itself. Im having issues with method 2. Overall I am trying to make a pyro sim narrower--and am using a custom velocity vector field to try and force the gas to stay more compressed, but I cant get convincing interaction with the divergence stage of the sim. I had been trying the gas advect for a while, but now Im trying the example 1 approach. I was curious as to whether or not the field force would work better because it is actually operating independent of the pyro solver with its nondivergent stage . Thanks! Quote Link to comment Share on other sites More sharing options...
tamagochy Posted April 12, 2019 Share Posted April 12, 2019 in volume source use vel as destination field and you no need advection. Quote Link to comment Share on other sites More sharing options...
