Find object level transformations
It's one of the areas of Houdini where I'm not super confident.
I'm trying to fetch object level transformations of a camera into a null in an asset.
The idea being you hook up a camera and get the transformations from it so it can translate a ready made lightrig.
I was trying to use the optransform function but didnt have much luck.
Can anyone help me out?
A simple test setup with a box, tube and 2 nulls inside a subnet.
If I just connect one of the nulls to a subnet input, it will become the input objects child and inherit the parent transform.
You can also fetch the transform manually with an expression. I used the NULL_PARENTED  object and opinputpath to fetch the second input object and get the tx channel.
Here's the expression to do that:
ch(opinputpath("../NULL_PARENTED", 0)/tx)
fetch_transform.hiplc
Edited by berglte
uploaded the sample scene
