Vex help
the foreach loops over all values in the i[]@pts array. Your attributes i@i and i@pt are integer attributes (not arrays), so each attribute value gets overwritten for each turn in the loop. At the end these attributes will have the value of the last run of the loop. If you use arrays for example, you will get all values from the loop.
for_each_pts.hipnc
