for each named primitive_problem
i am trying to run over named primitives, but the for each loop seems to pick randomly for each iteration which batch to process. i want the loop to respect the sorted primitives and run over each named primitive as it is in the geometry spreadsheet.
How does it pick the first batch for iteration number 0? can i change that?
image 1 is before the loop,sorted primitives
image 2 is inside the loop with a single pass to see iteration 0
As you can see the first batch the loop chooses to process is not the first batch as sorted before. First batch should be the one named color_229_229_0
