Issue with outputting HiRes fracture pieces
I'm having an issue while caching out some of my high res fracture pieces, after frame 600 (caching out a pieces a frame, into total around 10,000 pieces)  it seems to get stuck on the remesh 1 node and I cant figure out the issue. it seems to remesh other pieces fine but gets stuck at this point.
I'm also having another small issue with creating the detail on the pieces, I've set the vop to add detail on the "inside"group of the pieces (made from the vorinoi) the outsides faces should stay completely flat but doesn't.
HiRes.zip
