What's the difference between "ROP GLTF Output" node and "/out/GLTF" node?
The docs are a bit sparse on this topic. I know they exist in different networks, but otherwise what is the precise difference between the two? What are some use cases for each? Where should I be choosing one over the other? Also, what's the difference between the "Root Object" and "Objects" selection boxes in each? Is "Objects" just a filter for "Root Object"?
Yes, same basic node, just named slightly different because it's living in a non-ROP context. You're correct about the root object (the object below which exporting is done) and Objects (which of those objects that are children of the root object to export).
