draxysd Posted April 30, 2019 Share Posted April 30, 2019 Hi Guys, As the title says, is it possible to reflect a custom parameter made with a bind export node. For direct rays, it renders fine, but is it possible to get in the same Image Plane the reflection of that parameter in another object. I am creating an RGB matte and would need the mask also reflected. Hope I'm being clear enough. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Howitzer99 Posted May 16, 2019 Share Posted May 16, 2019 I haven't tried this in Houdini yet, but in other packages, you'd use something along the lines of a rayswitch node to change which shader is being evaluated for the different calculations (direct, reflection, refraction, etc). I've seen these mentioned for Redshift and V-Ray in Houdini, so I'd suggest looking into your renderer to see how this function is supported. Here is the Redshift docs: https://docs.redshift3d.com/display/RSDOCS/Ray+Switch Hope this helps. Quote Link to comment Share on other sites More sharing options...
