lexxkb Posted May 2, 2019 Share Posted May 2, 2019 (edited) Hi guys. I can not understand what the problem is. When I try to render the geometry on the point Houdini falls. I tried Houdini 17.5.173 and 17.5.229 and 17.0.459 (but this version cannot read the attribute “s@instancefile” and simply hides the object and does not fall). I also tried Redshift 2.6.39 and 2.6.40 I also checked on 2 different PCs wits RTX2080 and GTX980m In this case, the mantra makes the render right and does not fall. https://monosnap.com/file/ALqgtmx3qCPtmEu1cq4XKcKH3S1a8D Box.bgeo.scFetching info... *UP* *FIXED* the problem was in its node instance it was necessary to switch to display only mode. Dibag1.hip Edited May 2, 2019 by lexxkb Quote Link to comment Share on other sites More sharing options...
