Fix polygon with bad topology
AntoineSfx
At some point, after a triangulate 2D, I end up with a few bad polygons with this unpleasant topology.
( Arrows  are here to help you understand the topology)
The middle edge is not a shared edge. The points happen to be at same place, but they're not the same points. The polygon doubles back at its center.
How do I fix this ? I can't pass that monster downstream.
