How to make a cool explosion
Daniel16_16
Start with something like a sphere. Emit particles from it, shooting out in the shape you want. Copy a sphere with scattered points on it, onto each particle. Have each copied sphere trail, so you end up with a trail of points. That will be your fuel source. The length of the trail of points is the length of fuel you will have. How quickly that fuel dissipates is controlled on the pyro solver. Then play with the cooling rate, turbulence and disturbance to get what you are looking for.
