Gradient based of normal
MadMax50
Hey !
I am trying to achieve a gradient based on my normal direction. For example if my Normal is set to (0,0,1), i want a black and white falloff in that direction.
I already made this happen (sort of), but my issue is when I inverse the Normal like (0,0,-1),  my color turns black.
Is there anyway to fix this?
Thanks!
Normal_Gradient.hip
When you negate your Normals, your color values are going from 0 to -1.
You need to check the sign ( + or - ) of each vector component of the Normal. If it is negative, you need to take the compliment of the Position component [ ex. (1-P.x) ]  then do absolute value.
