Post Parent World Transform Information
Hello Houdini Folks,
I am working on a Outer Space Scene where i have the Earth and the Sun. The Suns orbit around the Earth is controlled via the Sun beeing parented to a Null in the Center of the Earth.
So far so good, but now i have no clue how to get the World Space Transformation Info from the Sun AFTER i have rotated the Null. The Problem is that the Transform of the Sunlight stays the same (i guess local).
I need the Suns Position to control a tool that generates a gradient over the earth dependend from the suns position - Tool works perfect but now after Parent-Rotation doesnt fetch the correct Transform Data.
Help would be very much appreciated cause im going nuts with such a basic thing since some hours :)
Cheers, Marco
5cd18244625bb_Bildschirmfoto2019-05-07um15_03_10.png.47487d38f1d88f85d550d844e08fe3c7.png
I found the solution by accident if somebody is interested.
if you click on a parameter with the right mouse you can choose "reference-scene Data". And from there you can pick any object in your scene, local transform or world transform.
So the solution was build in. I am still curious how to do that manually but for now it works like this.
