Recreating an ultracentrifuge
da_am
I'm trying to recreate an ultracentrifuge that seperates high density particles from low density particles. My current setup is two fluids with separate densities being emitted side by side to fill the container. Then once the container is fully filled I start up the "centrifuge", a pop axis force to spin everything at high speeds. The problem is it just acts as a blender and not a separator. I have a little divergence to pump up the fluid in the beginning but then it's removed. The densities are about 400 kg/m3 apart. I've tested fast and slower with different drags and settings but still just blends.
Anyone else try something like this? Maybe I'm missing something important (more than likely, ha).
Thanks!
Update: kind of working now adding some mass, drag, and applying the rotation only to the low density particles. Faking it till it makes it I guess.
Edited by da_am
updating info
