morn66 Posted May 17, 2019 Share Posted May 17, 2019 Hi everyone, I want to create a volume that contain a velocity att to my voxel. I realize that in some situations, vel can be store as one att but sometimes it duplicate it for each axis (vel.x, vel.y, vel.z). I guess it's probably faster to only have vel store one time as a vector attribute. How can I achieve that for this simple exemple below? Should I use a different node than "volume". Thanks Quote Link to comment Share on other sites More sharing options...
morn66 Posted May 17, 2019 Author Share Posted May 17, 2019 I have just found out that it is possible to convert vel to a vdb with a "convert vdb" and after use a "vdb vector to merge". Not sure if it's the right thing to do but it works. If you guys have extra info about that topic, let me know! Cheers 1 Quote Link to comment Share on other sites More sharing options...
char Posted May 17, 2019 Share Posted May 17, 2019 Volume SOP creates vel.x, vel.y, vel.z field which is different to what VDB from Particles would create. VDB from particles would only create one field (ex: vel). In H documentation for VOLUME SOP, there are a couple of things I can quote. Quote Stores a vector at each point. This is actually represented using three scalar fields (for example Cd.r, Cd.g, Cd.b) but Houdini knows to treat them as a single volume. You can use VDB Vector Merge to merge the .x, .y, .z fields into one single VDB field. Volume SOP (as far as I know), is an old way of creating volumes, now that OpenVDB workflow is around, it's more efficient in terms of resolution and speed. There is an in-depth explanation if you Google "Volume Houdini". Quote Because of the way this volume type is represented in memory, it does not require that you specify a box containing the volume; it can extend infinitely. Despite this, a VDB does define a 3D grid of voxels over the whole space. 1 2 Quote Link to comment Share on other sites More sharing options...
morn66 Posted May 17, 2019 Author Share Posted May 17, 2019 Thanks @char for the explanation! Quote Link to comment Share on other sites More sharing options...
morn66 Posted May 26, 2019 Author Share Posted May 26, 2019 I found out that: "vdb"node follow by "vdb activate" will create exactly the vel attribute as one. Doesn't need to use the vector merge. 2 Quote Link to comment Share on other sites More sharing options...
