pyro expand source h17
Hello!
I was going to ask how to do this but I figured it out and so I might as well post this in case someone else has the same problem. If you want to source expansion for pyro in houdini 17, we don't have the fluid source node. Instead we have the pyro source.  However, there is no expansion option for initialize. I remembered there was a shelf tool that auto-creates the nodes, so I tried it out. As it turns out (and seems confusing to me) you have to use the flip source then choose expand. Back in Dops you can use the volume source node and set it to expand also. Anyway, hope this helps-
Edited by ejr32123
