Rafal123 Posted June 29, 2006 Share Posted June 29, 2006 Hi people, I got two network rendering problems. My system is Windows XP_Pro. I have two hosts: host1, host2, and render from host1 using command: mantra -H host2 , and everything is fine. The problem begins when shader use texture from the net. Texture is "net mapped" \\host1\c\PRJ\bitmap.tga Unfortunately Mantra doesn't see it. In any case it's not a net issue. Texture is visible and readable but not by Mantra. I copied from host1 C:\Prj\bitmap.tga --> to --> host2 C:\Prj\bitmap.tga and it worked but... I don't have idea how to configure all stuff to make Mantra to see textures over the net I tried network disk mapping as: Z:\bitmap.tga but it also didn't help. Are there exist "mount" command from Linux under Windows? Can anybody help? Quote Link to comment Share on other sites More sharing options...
edward Posted June 29, 2006 Share Posted June 29, 2006 I think those should be forward slashes for Houdini. http://www.odforce.net/wiki/index.php/MantraRemoteRendering Quote Link to comment Share on other sites More sharing options...
Rafal123 Posted June 30, 2006 Author Share Posted June 30, 2006 thanks for answer Edward, now almost everything is fine... Quote Link to comment Share on other sites More sharing options...
