RBD constraint custom attribute not working h17.5
MadMax50
Hello,
I am working through the new RBD constraint tools in H17.5 , specifically the new options for the "RBD constraint properties" node . I am creating a custom stiffness attribute before the properties node and it seems like my attribute does not update even though I have it set to  the "scale by attribute option". It always resets to 1 and not my custom attribute. I am not sure what the issue is here...
I will attach my scene file for anyone that wants to take a look. Thank you
custom_stiffness_attib_h175.hip
seems to be working for me, if I check the primitive stiffness attribute on the Constraint Geometry output of rbdconstraintproperties3 I see it contains values that are your custom stiffness scaled by Stiffness parm value
@anim thanks for the reply. I seem to still be getting a constant value of 1 for my stiffness on the constraint geo after constraint properties. I restarted Houdini and still the same issue...Perhaps it's a bug. I am using Houdini 17.5.173 .
