drossxyu Posted June 8, 2019 Share Posted June 8, 2019 I've been trying to get a grasp on the FLIP workflow for the past 2 weeks or so and one thing i'm having trouble wrapping my head around is how to have my RBD toy object react elegantly to the FLIP simulation. It always seems to move in an erratic way with lots of weird little jitters and bumps yet the FLIP fluid beneath it appears to be pretty smooth. My scene scale is realistic. The baby pool is 3m in diameter I've tried lowering my collision separation to match my particle separation (currently 0.01). I had to lower this considerably to keep the water from leaking out of the bottom of the pool. Feedback scale is set to 1. The Density of the toy is lower than the water (50 vs 1000) I've tried increasing the overall substeps to 2 on the dopnet itself but it did not seem to make a difference. I used a convex decomposition on the toy to turn it into a bunch of packed convex pieces. It's set to convex hull in the RBD Packet Object bullet data options. Maybe this is the problem here? I don't see a way to create a volume representation of the toy. The pool and the ground are both static objects prepared as an SDF in SOPs and set to “Volume Sample”. I increased their uniform subdivisions to 60. I've attached the file if anyone has time to help me investigate. Cheers! https://streamable.com/s/7pwh4/mwtako flipToyTest_v3.hiplc Quote Link to comment Share on other sites More sharing options...
johnLIC Posted June 9, 2019 Share Posted June 9, 2019 I tried it with a default ground plane instead of the ground geo. It seemed to behave a little better. It still bounces around, but maybe that's what it's supposed to do. It's pretty light. Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted June 9, 2019 Share Posted June 9, 2019 Hi. I've made some changes in your scene. First made bottom of the pool a bit thicker. Second I've used RBD Object DOP instead of RBD Packed Object DOP for Bullet and volume collision for it. Third value of collision separation should be lower then particle separation (it there is in the help-card), so I've used expression ch("particlesep")*0.5. Other changes like decreasing particle separation, bypassing some DOPs, changing feedback scale I've made for the test purpose only. flipToyTest_v3_01.hipnc Quote Link to comment Share on other sites More sharing options...
drossxyu Posted June 9, 2019 Author Share Posted June 9, 2019 This is working a lot better! Thank you. One thing I noticed is that you're using the default "Ray Intersect" method for your RBD Object DOP collision method. This seems to work fine. What I don't understand is why I'm unable to successfully prepare my collision SDF for the rubber toy in SOPs without strange results. I did a simple conversion of the rubber toy with a vdbFromPolygons set to surface, set my RBD Object DOP to "volume sample", and pointed the volume proxy to this output. You can see below that the toy just flickers in and out of existence and ultimately disappears. I also prepared my collision geometry for the bullet collisions by fracturing it first so that I can have more accurate RBD collisions but as you can see with the "Ray Intersect" method it sees the fractured geometry and creates a weird and i'm assuming inaccurate collision volume. https://streamable.com/v1y28 Quote Link to comment Share on other sites More sharing options...
drossxyu Posted June 9, 2019 Author Share Posted June 9, 2019 Here's another question: When I read my simulation back into SOPs I have both a Dop Import Fields to bring in my FLIP data (Geometry, surface and vel fields) and a separate Dop Import to bring in my simulated rbdobject1 rubber toy (set to fetch geometry). I'm writing both of these imports using separate rop_geometry_output nodes but it seems like it's having to calculate the sim twice. Is there any way around this? Seems redundant. Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted June 10, 2019 Share Posted June 10, 2019 (edited) 14 hours ago, drossxyu said: What I don't understand is why I'm unable to successfully prepare my collision SDF for the rubber toy in SOPs without strange results. I did a simple conversion of the rubber toy with a vdbFromPolygons set to surface, set my RBD Object DOP to "volume sample", and pointed the volume proxy to this output. You can see below that the toy just flickers in and out of existence and ultimately disappears. It works fine for me. This is your scene with Volume Sample mode and Proxy Volume: flipToyTest_v3_02.hipnc 14 hours ago, drossxyu said: I also prepared my collision geometry for the bullet collisions by fracturing it first so that I can have more accurate RBD collisions but as you can see with the "Ray Intersect" method it sees the fractured geometry and creates a weird and i'm assuming inaccurate collision volume. You no need to fracture it. As i know flip works properly with RBD Object only and volume collision , not with RBD Packed Object and convex hull. 8 hours ago, drossxyu said: I'm writing both of these imports using separate rop_geometry_output nodes but it seems like it's having to calculate the sim twice. Is there any way around this? Seems redundant. Did you check Initialize Simulation OPs parameter into the ROP Geometry Output? If it is on then all network will be re-simulate. Edited June 10, 2019 by vicvvsh 2 Quote Link to comment Share on other sites More sharing options...
