lubitel Posted June 9, 2019 Share Posted June 9, 2019 This can probably be done in many ways without using TOPs.... I have in several places four filecache nodes that I want to be able to run one after another in a particular order. They exist in different levels and dont know about each other at this point. I wonder what would be a good way to have them run in sequence. Is TOPs overkill for such a task? Thank you. TOPS_FilecacheExample.hipnc Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted June 10, 2019 Share Posted June 10, 2019 TOPs is a fine way to work with these. It's pretty much the replacement for ROPs which you can also do this in. If you want a python base list that just presses the buttons in series you can use something like this. https://www.orbolt.com/asset/LaidlawFX::Queue::1.0 - Pictures and Orbolt https://github.com/LaidlawFX/LaidlawFX - Code base. Quote Link to comment Share on other sites More sharing options...
